Contributor
7840 FCIP and redunancy and Cisco Nexus 5548
Hi
I am implementing FCIP for my Hitachi Universal Replicator  with 4 box solution .  (2 7840 Boxes at each site) .    We are considering the solution at 7840   and Network level . These switches are connected to Cisco 5548  with Port channel configured.
How can we achieve the HA with setup and whether Broacde 7840 supports Port channeling .  I have gone through some docuemnets  and found similar concept of Extensive Trunking.  There are docuements  avialable only for commands , not  much related to design
Regular Contributor
Re: 7840 FCIP and redunancy and Cisco Nexus 5548
Hi,
HA you will get with FCIP-Trunking. So several circuits in one VE-Port and no need for Port-Channels.
Kind Regards
Ralf
Contributor
Thanks for quick reply . Any idea  how broacde communicates to CISCO 5548 ? we  are used 10G SFP to connect to it, however cisco Hitahi came back with saying , Brocade ge 10G SFP doesnt support on cisco 5548
Any link for best practises for 7840 connecting to Core Router/Firewall ?
@ralf.schlosser wrote:
Hi,
External Moderator
AFAIK,
Cisco 5548 don't support FCIP, for this reason you cannot create a FCIP tunnel with Brocade 7840.
TechHelp24
Contributor
Thanks Antonio for the reply   Now we are checking the possibilities 7840 to Active/Passive fireall
Any link   for Brocade 7840 compatibility with Cisco Switches/ ASA Firewall ?
@There is  below which talks @ the SAN connection , not FCIP connection.
https://www.brocade.com/content/dam/common/documents/content-types/product-matrix/brocade-compatibility-matrix-fos-7x-mx.pdf
@Antonio Bongiorno TechHelp24 wrote:
AFAIK,
External Moderator
Hi,
->Now we are checking the possibilities 7840 to Active/Passive fireall
I think, but is just my opinion, such a config is not supported for follow reason.
the 10G Port on Brocade can be configured as a simple Uplink, but AFAIK, it cannot be configured or set as NPIV.
NPIV is required on cisco side in order to get a link up on 5548
About ASA Firewall, I'm not confident with the plattforms, but i think 95% such a config is not supported.
If I'm wrong, please ignore my post.
TechHelp24
External Moderator
I found follow instruction from Extension Guide
http://www.brocade.com/content/html/en/administration-guide/fos-740-extensionguide/GUID-8C914D4A-E78C-4414-8487-2EAA9FDF15B3.html
a similarly config as per you request show to be supported from 1GE Port.
TechHelp24
Contributor
Thanks
Any idea which module of Cisco nexus supports FCIP traffic as uplink ,   I have found  Nexus 7K  passes FCIP traffic further  . Hitachi is recommending to  replace  Cisco 5548 with 5596 .
As u mentioned , the chances of cross connection firewall would be slip as Passive  F/W can pass traffic further and we already in risk of losing 2 path
External Moderator
->Hitachi is recommending to  replace  Cisco 5548 with 5596 .
xx48 or xx96 Models, are EXACT!!! the same platforms with same Features, the only one Difference is Port Count.
To be honestly is to me a mystery why HDS give such you such a recommendation ????
well, if you want to replace the CISCO, then replace it with another Brocade 7840, and resolve all the problem.
As per my opinion is a most easy solutions.
-->>Any idea which module of Cisco nexus supports FCIP traffic as uplink ,
No sorry. As I said in my other post yesterday, AFAIK, neither the Nexus 5548 nor the 5596 don't support FCIP, apart of that I'm unable to assist you with such a plattforms.
I would suggest to ask in Cisco Forum, we are here by Brocade.
TechHelp24
