New Contributor
7.4.0a BRCD 6505 with single Power Supply MAPS Configuration
Hi , does anyone know which combination of MAPSrules and values are usable for BRCD6505 with only one Power Supply.
It seem that after update to 7.4.0a a mapspolicy for a switch with two power supplys is enabled.
All predefined policys are configured with the same values.
defCHASSISBAD_PWR_MARG                  |CHASSIS(BAD_PWR/NONE>=1)                          |SW_MARGINAL,SNMP,EMAIL     |
defCHASSISBAD_PWR_CRIT                  |CHASSIS(BAD_PWR/NONE>=2)                          |SW_CRITICAL,SNMP,EMAIL     |
defCHASSISBAD_FAN_MARG                  |CHASSIS(BAD_FAN/NONE>=1)                          |SW_MARGINAL,SNMP,EMAIL     |
defCHASSISBAD_FAN_CRIT                  |CHASSIS(BAD_FAN/NONE>=2)                          |SW_CRITICAL,SNMP,EMAIL     |
regards
Lutz
Valued Contributor
Re: 7.4.0a BRCD 6505 with single Power Supply MAPS Configuration
As already discussed: clone one of the policies, modify your new copy and activate it.
New Contributor
Hi Alexey ,
thx for your response but my question is regarding to the correct values.
The default values and rules are for a switch with two power supplies.
We have only one power supplie , so it indicates a marginal warning.
What I wnat is to suppress the warning for the missing power supplie and fan.
regards Lutz
External Moderator
Lutz,
Forgot and ignore all the post here in the community about this error message in Brocade 6505.
Symptom : MAPS indicates the switch state is marginal if only one power supply unit is present on Brocade 6505.
Conditions : This is only applicable to Brocade 6505 switch.
Workaround : This erroneous message may be ignored.
This is a Defect000564334  and there - AFAIK - is no workaround today.
The defect will be closed in coming next Release.
TechHelp24
Occasional Visitor
Hi,
Do we have a Document with this information? i'm having the same problem.
External Moderator
[ Edited ]
The DEFECT as be reported with FOS 7.4.1a
TechHelp24
