Turn on suggestions
Showing results for
09-09-2016 12:11 AM
Am trying to solve the problem as two 6510 performing config default unable to form a fabic giving Segmented Zone error . As metioned Below one of the Fabric having AD Feature: Active how do I disable the feature . I believe this causing the issue .
Regards,
Jay
BDC-IDF-Core-A-6510:admin> switchshow
switchName: BDC-IDF-Core-A-6510
switchType: 109.1
switchState: Online
switchMode: Native
switchRole: Principal
switchDomain: 100
switchId: fffc64
switchWwn: 10:00:00:27:f8:8f:92:11
zoning: ON (EPV_IDF_Core_A)
switchBeacon: OFF
FC Router: OFF
FC Router BB Fabric ID: 1
Address Mode: 0
HIF Mode: OFF
BDC-IDF-Core-B-6510:admin> switchshow
switchName: BDC-IDF-Core-B-6510
switchType: 109.1
switchState: Online
switchMode: Native
switchDomain: 90
switchId: fffc5a
switchWwn: 10:00:00:27:f8:8c:be:39
AD Feature: Active
Current AD: 0
zoning: OFF
switchBeacon: OFF
FC Router: OFF
Address Mode: 0
HIF Mode: OFF
09-09-2016 12:52 AM
Please, give the output of "ad --show" in 255 AD-context
09-09-2016 07:14 AM
Also please check if the defzone settings do match on both sides (defzone --show)
09-12-2016 06:38 AM
Further, details on how clean out / remote AD per "Deleting all user-defined Admin Domains non-disruptively" are at
09-19-2016 03:52 AM
09-19-2016 04:26 AM
Tried to clear the Config but couldn't .
BDC-IDF-Core-B-6510:AD255:admin> ad --clear -f
You are about to delete all ADs definitions and zone databases under them.
This could involve multiple independent zone transactions and
no auto recovery will be done in case of failure in the middle.
Do you want to clear all admin domains (yes, y, no, n): [no] t^?y
Input not acceptable, please re-enter
Do you want to clear all admin domains (yes, y, no, n): [no] y
BDC-IDF-Core-B-6510:AD255:admin> ad --apply
Set defzone mode to noaccess in AD0 context before configuring ADs
BDC-IDF-Core-B-6510:AD255:admin> ad --show
Current AD Number: 255 AD Name: AD255
Transaction buffer configuration:
no configuration
Defined configuration:
AD Number: 0 AD Name: AD0 State: Active
Device WWN members: 50:06:01:60:b0:22:03:f0;
21:00:00:e0:8b:94:8f:f0;
21:00:00:e0:8b:94:3a:f1;
20:00:00:e0:8b:94:8f:f0;
20:00:00:e0:8b:94:3a:f1;
50:06:01:68:30:22:03:f0;
Effective configuration:
no configuration
09-19-2016 04:48 AM - edited 09-19-2016 04:50 AM
Hi!
For the first make defzone --noaccess and cfgsave in all ADs.
For the second try ad --deactivate AD_ID (in your case - 0) in 255 context, ad --save.
Try ad --clear -f from 255 context and ad --save.
