Occasional Contributor
Accepted Solution
5300 setup help
HI, I am looking for some help with a 5300 FC switch.  A company was nice enough to donate a 5300 (80port active) switch to us to replace our older Qlogic 4GB 5600 switches.  With the 5600 switch by deafult every port saw every port, which is how I want to setup the 5300.  But I am having problems getting that accomplished with the 5300. I can plug storage and HBA's into the 5300 and get link lights, but they don't see each other (they are all 4GB connections btw).  I did a zonedef --allaccess, rebooted and no change.    Does anyone have an tips that could help me out?  I'm far from a FC expert and feel like I am getting in over my head on this one.
Thanks,
Scott
Re: 5300 setup help
Hello Scott,
To give you the correct steps to get all devices to see each other I would have to know the current FOS version on the 5300.  What license are loaded on this 5300?
Regards
Exension_Guy
Peter O'Brien
Re: 5300 setup help
[ Edited ]
Attached are the licenses it has.  I've made a little headway in editing zones, but am still a little confused.  IS there a way to enable zones without a device connected for "future" expansion?  Say I want ports 1-10 to be storage ports and 11-20 to be HBA ports, even though I only have storage devies connected to ports 1-5 and HBA's connected to the ports 11-15.  Can i create a zone that allows devies to be connected to 6-10 and 16-20 at a later time even the they aren't present when creating the zone?
Ideally, I would like to have a zone where all of ports 1-31 are for storage and 33-79 are for HBAs and they remain active/open
  I've been using the web interface fyi.
Thanks again for all your help!
Re: 5300 setup help
Hello Scott,
You are on to the correct solution. Do you have the current FOS version? You can use port based zoning https://www.youtube.com/watch?v=ebvNhLGWWcE   Sorry about the bad audio on the video, just mute it.
After you finish the zoning please do the following:
Download the SANHealth free application.
Run SANHealth,
Send the encryped SANHealth file to the SANHealth admin email address.
You will get a spread sheet with all the zones.
You will get a Visio drawing of the attached devices.
You will get a data base to compare future new zones.
Regards
Extension_Guy
Peter O'Brien
Re: 5300 setup help
YES!!!! Thank you so much, that video answered my questions on how to do what I wanted to do.
Scott
