Anonymous
48K ISL-Trunk problem
Hi all,
this is Max Gregis from Milan, Italy
i've some problems on ISL-Trunk links between  2 48000 sw.
I've random link problem on single gbic, that creates impact on entire fabric . The gbic is not the same every time.
i've already verified it's not a HWD problem  , i've already opened a case to our vendor (HP sold us these two 48k) and the support told me it's not a hwd problem and i've to check fc cabling.
After specified control we've verified FC cabling is ok.
i've some question:
Is it possibile to configure two different ISL-TRUNKING on a single octect on 48K?
How can i test isl and trunking (via CLI or WEB interface)?
for enabling advanced trunking is it necessary to have a license?
is it possibile to use DPS or DLS on trunking?
any ideas?
Thanks in advance
max
Anonymous
Re: 48K ISL-Trunk problem
Hi max,
would you mind posting portShow output for affected E-ports on both sides.
Linar
Anonymous
hi,
thanks for your answwer.
this is portshow of CORE switch
INVF11D145ENIC:admin> portshow 1/6
portName: Riservato ISL tra CORE
portHealth: HEALTHY
Authentication: None
portDisableReason: None
portCFlags: 0x1
portFlags: 0x10004907    PRESENT ACTIVE E_PORT T_PORT T_MASTER G_PORT U_PORT LOGICAL_ONLINE LOGIN LED
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portScn:   16   E_Port    Trunk master port Flow control mode 4
port generation number:    0
portId:    910600
portIfId:    43120030
portWwn:   20:06:00:05:1e:36:6e:0e
portWwn of device(s) connected:
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Interrupts:        0          Link_failure: 0          Frjt:         0
Unknown:           0          Loss_of_sync: 0          Fbsy:         0
Lli:               0          Loss_of_sig:  0
Proc_rqrd:         9334590    Protocol_err: 0
Timed_out:         0          Invalid_word: 0
Rx_flushed:        0          Invalid_crc:  0
Tx_unavail:        0          Delim_err:    0
Free_buffer:       0          Address_err:  0
Overrun:           0          Lr_in:        0
Suspended:         0          Lr_out:       0
Parity_err:        0          Ols_in:       0
2_parity_err:      0          Ols_out:      0
CMI_bus_err:       0
Port part of other ADs: No
INVF11D145ENIC:admin> portshow 1/7
portHealth: HEALTHY
portCFlags: 0x1
portFlags: 0x4903        PRESENT ACTIVE E_PORT T_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN LED
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portScn:   16   E_Port    Trunk port Flow control mode 4
portId:    910700
portIfId:    43120030
portWwn:   20:07:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         0          Protocol_err: 0
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D145ENIC:admin> portshow 4/7
portHealth: HEALTHY
portCFlags: 0x1
portFlags: 0x903         PRESENT ACTIVE E_PORT T_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    913700
portIfId:    43420030
portWwn:   20:37:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D145ENIC:admin> portshow 4/6
portHealth: HEALTHY
portCFlags: 0x1
portFlags: 0x10000903    PRESENT ACTIVE E_PORT T_PORT T_MASTER G_PORT U_PORT LOGICAL_ONLINE LOGIN
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    913600
portIfId:    43420030
portWwn:   20:36:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         4764275    Protocol_err: 0
Timed_out:         0          Invalid_word: 1
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D145ENIC:admin> portshow 9/6
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    916600
portIfId:    43920030
portWwn:   20:66:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         4729710    Protocol_err: 0
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D145ENIC:admin> portshow 9/7
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    916700
portIfId:    43920030
portWwn:   20:67:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D145ENIC:admin> portshow 10/7
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    917700
portIfId:    43a20030
portWwn:   20:77:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D145ENIC:admin> portshow 10/6
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    917600
portIfId:    43a20030
portWwn:   20:76:00:05:1e:36:6e:0e
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         4708780    Protocol_err: 0
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
Anonymous
hi Linar,
and this is portshow of EDGE switch
thanks again
Max
> portshow 1/0
portName: ISL INVF11D88ENIC
portHealth: HEALTHY
portCFlags: 0x1
portFlags: 0x10000907    PRESENT ACTIVE E_PORT T_PORT T_MASTER G_PORT U_PORT LOGICAL_ONLINE LOGIN
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a0000
portIfId:    43120036
portWwn:   20:00:00:05:1e:36:2b:ce
Distance:  standard <= 10km
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         58918092   Protocol_err: 0
Timed_out:         0          Invalid_word: 3
Rx_flushed:        0          Invalid_crc:  2
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 1/1
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a0100
portIfId:    43120036
portWwn:   20:01:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Timed_out:         0          Invalid_word: 2
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 1/2
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a0200
portIfId:    43120036
portWwn:   20:02:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 2/1
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a1100
portIfId:    43220037
portWwn:   20:11:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         33446332   Protocol_err: 0
Timed_out:         0          Invalid_word: 49
Rx_flushed:        0          Invalid_crc:  43
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 2/2
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a1200
portIfId:    43220037
portWwn:   20:12:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 2/3
portName: SUN_INV_ensv17zi_hba0
portHealth: HEALTHY
portCFlags: 0x1
portFlags: 0x24b03       PRESENT ACTIVE F_PORT G_PORT U_PORT LOGICAL_ONLINE LOGIN NOELP LED ACCEPT FLOGI
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portScn:   32   F_Port
port generation number:    4506
portId:    5a1300
portIfId:    43220031
portWwn:   20:13:00:05:1e:36:2b:ce
        21:00:00:1b:32:85:03:68
Distance:  normal
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Interrupts:        20         Link_failure: 0          Frjt:         0
Unknown:           0          Loss_of_sync: 2          Fbsy:         0
Lli:               14         Loss_of_sig:  2
Proc_rqrd:         482        Protocol_err: 0
Timed_out:         0          Invalid_word: 8
Overrun:           0          Lr_in:        2
2_parity_err:      0          Ols_out:      2
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 3/0
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a2000
portIfId:    43320034
portWwn:   20:20:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         34535288   Protocol_err: 0
Timed_out:         0          Invalid_word: 40
Rx_flushed:        0          Invalid_crc:  37
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 3/1
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a2100
portIfId:    43320034
portWwn:   20:21:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 3/2
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a2200
portIfId:    43320034
portWwn:   20:22:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 4/0
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a3000
portIfId:    43420034
portWwn:   20:30:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Proc_rqrd:         31226291   Protocol_err: 0
Timed_out:         0          Invalid_word: 21
Rx_flushed:        0          Invalid_crc:  21
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 4/1
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a3100
portIfId:    43420034
portWwn:   20:31:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
INVF11D90ENIE:admin> portshow 4/2
portHealth: HEALTHY
portCFlags: 0x1
portType:  10.0
portState: 1    Online
portPhys:  6    In_Sync
portId:    5a3200
portIfId:    43420034
portWwn:   20:32:00:05:1e:36:2b:ce
portSpeed: N4Gbps
LE domain: 0
FC Fastwrite: OFF
Overrun:           0          Lr_in:        0
CMI_bus_err:       0
Anonymous
Hi Max,
I think portcfgtrunkport (cli) may help you. By default trunking is enabled (unless trunking license is not available of course), you can disable it if you want.
You can use spinfab under cli
Hope this helps,
Kind regards,
david
Anonymous
Hi DMercier,
thanks for yourt answer.
My 48ks are on production and i can't test anything and i can't do any command without my customer's special permission , on those switches.
My customer works in this way, so..........
I assume i can configure more tha one trunk in a octect on 48k qith portcfgtrunkport ad this issue can not create problem on these two isl-trink.
about spinfab i can't try it for the same reason. I i understood well spinfab makes some test on isl link, also up&down sil-trunk link i suppose.....
Anonymous
You won't be able to test / reproduce any issue without having any impact on your production fabric.
Best approach is to try working during periods with less traffic, to have as few impact as possible.
Spinfab won't down/up links but will generate lots of traffic wich may produce some congestion on tested links.
The only way to go forward may to configure Fabricwatch and track any errors almost on ISLs. Since 6.3.1b Bottleneck Detection may also help without impacting production.
Kind regards,
david
Anonymous
Hi David,
thanks for your advices,
i'm going to try to gain a window to execute these tests...
I asked to my customer and i said to me we haven't Fabric Watch (sigh!)
thanks again
Max
Anonymous
It's going to be very hard to investigate !
Last advice before testing your ISLs in charge : reset all counters first (statsclear; slotstatsclear), then you'll have a baseline for work.
Good luck
Kind regards,
david
Anonymous
Hello Max,
can you specify this in a more detailed version:
I think David provide a good idea to clear the error counter and point to the affected ports.
As well some errors are send to the entire fabric and will be visible on the receiving end of the ISL if it has passed one.
Did you have any errorlog entries or a flapping device ports in the fabric?
Andreas
