Contributor
4024 in Access Gateway - mode and IP over Fibre Channel
Hi!
Do the embedded switches support IP over Fibre Channel in AG-mode? I configured an IP-address in fc0-interface, it's up and seems ok, but nothing seems to be able to contact it. We're running FOS 6.1.2 in edge-switch and in AG...
External Moderator
Re: 4024 in Access Gateway - mode and IP over Fibre Channel
you mean FCIP in a IBM Blade Center Switch ?
TechHelp24
Contributor
Noo, talking IP over Fibrechannel in HP-blade senter...
External Moderator
I know
FCIP - Fibre Channel over IP protocol.
and
FCoE - Fibre Channel over 10 Gbit/sec Ethernet networks.
FCIP is only supported in FCR Switches, like the Brocade AP7500 / FR4-18i  / AP7420
FCoE is Supported in the Brocade 8000
TechHelp24
Contributor
Yup, these would be transmitting FC over IP- or Etnernet. I wanted to transmit IP over FC. (IPFC)
Contributor
External Moderator
Miika,
I think we have misunderstood us....
To you question, No this is Direct not Supported.
Is Supported only trough FCR capable Device as mentioned, or Direct whit the Brocade 7600 / FC4-16E Blade
TechHelp24
Contributor
Yeah, saw that in the name-server.... Doesn't work...
