Anonymous
3250 firmware problems
I have a 3250 that Is currently in a bit of a loop and im not sure how to get it out of it. I just acquired the switch used and so I have no prior history of it. It seems like the secondary partition might be corrupt or something but for whatever reason it is just in this endless loop trying to download new firmware but failing miserably. I have tried to manually initiate the firmware download but it fails the sanity check (im about ready to fail the sanity check myself!)
SanSW3:admin> firmwareshow
Primary version: v5.1.1
Secondary version: Unknown
SanSW3:admin> version
Kernel: 2.4.19
Fabric OS: v5.1.1
Made on: Thu Sep 28 00:22:26 2006
Flash: Tue Oct 10 00:02:32 2006
BootProm: 4.5.3
SanSW3:admin> firmwarecommit
Validating primary partition...
Repairing the secondary partition now.
Please wait ...
rsync: error writing 15947 unbuffered bytes - exiting: Broken pipe
rsync error: error in rsync protocol data stream (code 12) at io.c(465)
rsync: error writing 69 unbuffered bytes - exiting: Broken pipe
Failed to sync partitions (0xc00).
Please retry firmwarecommit.
SanSW3:admin> firmwaredownloadstatus
: Tue Oct 10 00:00:33 2006
Firmware is being downloaded to the switch. This step may take up to 30 minutes.
: Tue Oct 10 00:05:59 2006
Firmware has been downloaded to the secondary partition of the switch.
: Tue Oct 10 00:08:38 2006
The firmware commit operation has started. This may take up to 10 minutes.
: Tue Oct 10 00:11:16 2006
Firmware commit failed - Firmwarecommit failed. (0x1a)
: Tue Oct 10 00:18:15 2006
: Tue Oct 10 00:19:12 2006
: Tue Oct 10 00:19:28 2006
: Tue Oct 10 00:20:30 2006
: Tue Oct 10 00:24:42 2006
Firmware commit operation has started to restore the secondary partition.
: Tue Oct 10 00:24:43 2006
: Tue Oct 10 00:25:58 2006
: Tue Oct 10 00:27:12 2006
Firmwarerestore is entered. System will reboot and a firmware commit operation .
Unable to restore the secondary partition. Please use firmwaredownloadstatus an)
And thats the endless loop the switch is in. I am unable to access any of the administrative functions of the GUI while this is happening so im unable to configure the switch. However it appears that everything is functional.
Any help is GREATLY appreciated.
Thanks!
External Moderator
Re: 3250 firmware problems
suparuki,
i note your have start a Firmware Download.
what kind of release was loaded before you Upograde to v5.1.1 ?
TechHelp24
TechHelp24
Anonymous
Thats the thing I have not upgraded this to 5.1.1 This is how I received it. I cant seem to stop it trying to download new firmware but I cant intervene and tell it where new firmware actually is. Its like it keeps trying to commit the 5.1.1 ver to the secondary partition and for whatever reason it cant. SO it tries to bring down a new ver but I have no clue where it thinks its trying to get it from.
Thank you for replying im desperate and really need help on this.
