New Contributor
3250 Silkworm Firmware upgrades ?
I have a Silkworm 3250 and Fabric OS of 4.2.0b. I would like to upgrade the firmware and such to the most current version to support Solaris 10 environment.**********************************************************************<BR>READ THE TERMS OF THE AGREEMENT ("AGREEMENT") IN THE LEGAL_LICENSE.TXT<BR>FILE CAREFULLY BEFORE USING THIS SOFTWARE. BY USING THE SOFTWARE, YOU<BR>AGREE TO THE TERMS OF THIS AGREEMENT. IF YOU DO NOT AGREE TO ALL OF THE<BR>TERMS, PROMPTLY DESTROY THE UNUSED SOFTWARE.<BR>*********************************************************************<BR><BR>Keywords: brocade 2g 4g fibre channel switch firmware fos 200e 3250 3850 3900 4100 4900 5000 7500 24000 48000<BR>Synopsis: Brocade FOS v5.3.0 patch for 200e 3250 3850 3900 4100 4900 5000 7500 24000 48000<BR>Date: Aug/17/2007<BR><BR><BR>Install Requirements: NA <BR> <BR>Solaris Release: 8 8_x86 9 9_x86 10 10_x86<BR><BR>SunOS Release: 5.8 5.8_x86 5.9 5.9_x86 5.10 5.10_x86<BR><BR>Unbundled Product: Brocade Fibre Channel Switch Firmware<BR><BR>Unbundled Release: N/A<BR><BR>Xref: <BR><BR>Topic: Brocade FOS 5.3.0 firmware release for 200e 3250 3850 3900 4100 4900 5000 7500 24000 48000<BR><BR>Relevant Architectures: sparc i386<BR><BR>BugId's fixed with this patch: <BR><BR>Changes incorporated in this version: <BR><BR>Patches accumulated and obsoleted by this patch: 122185-02<BR><BR>Patches which conflict with this patch: <BR><BR>Patches required with this patch: <BR><BR>Obsoleted by: <BR><BR>Files included with this patch: <BR><BR>LEGAL_LICENSE.TXT<BR>MIBs.zip<BR>README.124898-06<BR>patchinfo<BR>v5.3.0.zip<BR>v5.3.0_releasenotes_v2.0.pdf<BR><BR>Problem Description:<BR><BR>Note: Special Instructions:<BR>----
<BR>v5.3.0 is incompatible with the Brocade 12000 Director. Use v5.0.4a or later for upgrade<BR>on 12000 models. See SunSolve Patch 119552 for the latest available firmware for the SilkWorm 12000.<BR> <BR>IMPORTANT IMPORTANT IMPORTANT<BR>************************************************<BR> The items made available through this website<BR> are subject to United States export laws and<BR> may be subject to export and import laws<BR> of other countries. You agree to strictly comply<BR> with all such laws and obtain licenses to<BR> export, re-export, or import as may be required.<BR> Unless expressly authorized by the United States<BR> Government to do so you will not, directly or<BR> indirectly, export or re-export the items made<BR> available through this website, nor direct the<BR> items therefrom, to any embargoed or restricted<BR> country identified in the United States export<BR> laws, including but not limited to the Export<BR> Administration Regulations (15 C.F.R. Parts<BR> 730-774).<BR>*************************************************--
<BR> <BR>This is not an OS patch and is not installed with the standard Solaris <BR>patchadd(1M) command. After unpacking the patch, follow the "Special Install <BR>Instructions" below to upgrade the FC switch firmware.<BR> <BR>Brocade FOS 5.3.0 firmware release for 200e 3250 3850 3900 4100 4900<BR>5000 7500 24000 48000. To install using other platforms, minimum FTP services <BR>is required. Please see Brocade document 53-1000448-01.<BR> <BR> <BR>Prerequisites for installing the new firmware include:<BR> <BR> * FTP server (solaris host).<BR> <BR> * An Ethernet connection from a Solaris host to the Brocade Switch. To use an <BR> Ethernet connection, the Brocade FC switch must have an IP address assigned<BR> and the user must know the admin password assigned to the switch.<BR> <BR>Unpack the patch into any convenient directory such as /var/tmp, and refer to <BR>the Special Install Instructions below.<BR><BR>Special Install Instructions:<BR>
<BR>Sun supports firmware upgrades within two feature releases (a feature<BR>release is a major release indicated by the<BR>second digit "Y" of the release number, for example, X.Y.Z); while<BR>upgrades of two releases is supported, single<BR>release upgrades are recommended. Following are the major upgrade<BR>versions for the Fabric OS:<BR>- v4.0x<BR>- v4.1x<BR>- v4.2x<BR>- v4.4x<BR>- v5.0x<BR>- v5.1x<BR>- v5.2x<BR>- v5.3x"<BR><BR> <BR>This firmware upgrade procedure will not cause I/O interruption if using FW <BR>v4.1.0 or greater.<BR> <BR> <BR> 1. Change your working directory to the directory in which the patch<BR> was saved. Then unzip the firmware file, v5.3.0.zip. <BR> and confirm that the v5.3.0 directory is present.<BR> Do not link release.plist in this directory.<BR> <BR> 2. Invoke telnet using the following syntax:<BR> <BR> telnet <hostname><BR> <BR> where <hostname> is the name or IP address of the FC switch. If security<BR> is enabled, you will need sectelnet application or ssh. <BR> <BR> <BR> 3. Verify that the current switch firmware by typing the<BR> following command at the "admin>" prompt:<BR> <BR> version<BR> <BR>EXAMPLE:<BR> sw0:admin> version<BR> Kernel: 2.4.19<BR> Fabric OS: v5.0.3 <
- be restarted. Do you want to continue : y firmwareshow
Primary partition: v5.3.0
Secondary Partition: v5.3.0
24000/48000 EXAMPLE:
switch:admin> firmwareshow
Slot Name Primary/Secondary Versions Status
<BR>5 CP0 v5.3.0 Standby<BR> v5.3.0<BR> <BR>6 CP1 v5.3.0 Active *<BR> v5.3.0<BR> <BR> <BR>Reference<BR>
External Moderator
Re: 3250 Silkworm Firmware upgrades ?
By Upgrade from Old FabOS 4.2.x you must upgtrade in more step.If you not upgrade inmore step get a risk to damaged the Compact Flash in the Switch.
TechHelp24
New Contributor
Thought someone might say that.. thank you &lt;!graemlin::)&gt;If you not upgrade inmore step get a risk to damaged the Compact Flash in the Switch.
External Moderator
Hi,
TechHelp24
New Contributor
Thank you ... will try and do upgrades
