Turn on suggestions
Showing results for
02-21-2006 11:54 AM
Hi I have 2 2800's. One works fine, but the other won't boot. I've made a serial cable to hookup to the internal serial port. And the messages I get are as follows:
03-01-2006 12:07 PM
Anyone? Bump!
03-02-2006 08:39 PM
after you net boot the 2800 try doing a firmwaredownload. The net boot does not put the firmware into flash, just RAM. I would guess that the flash is just dead.
