Anonymous
24000 Director - Flash Monitor
When viewing the Switch Health Report it is stating the FLASH is MARGINAL. I don't see anything in the event logs though. Is this where the filesystem that contains the code is located I assume? Could it be running out of space? Does anyone know how to view file system status?
Anonymous
Re: 24000 Director - Flash Monitor
Hey, Olivier
Anonymous
What is the default root password?
External Moderator
Rob,root password is by default "fibranne"
TechHelp24
Anonymous
You should contact your switch vendor to get it, as much of them change it.Olivier
Anonymous
It's currently running FOS 5.3.0. It was shipped with 4.4.0c. I tried the fibranne password with no luck.
External Moderator
Rob,execute here the command "supportshow" for details refer the Command Reference Guide.
TechHelp24
Anonymous
Filesystem 1k-blocks Used Available Use% Mounted onI was able to get in via root & run the df. Is the Use% a little high? Are there any directories I can clean out? I'm assuming it has copies of all the old code when running the updates.
External Moderator
86% is very high.if you find the command, execute this to delete the log in the job folder.
TechHelp24
Anonymous
I don't see any "logclean" type commands, but I'm looking through the command reference guide to see if there are any like commands. If anyone else knows of any, let me know, please.rob
