Turn on suggestions
Showing results for
04-22-2015 03:01 AM
Hi,
I've two DS300 connected with two ISL.
Both are online, but i can't have upstream and downstream, only one.
What config i've miss ?
Thanks a lot,
Regards
Jérôme
04-22-2015 03:40 AM
04-22-2015 03:45 AM
04-22-2015 04:19 AM
Thanks alexey !
I've replaced two DS200E, with DS300B and before ISL Links on both switch have upstream and downstream terms.
But now, with DS300B, only one patch is listed as downstream on principal switch.
The output of islshow seems to be ok, i can see all my isl :
swsanrdmst:admin> islshow
1: 5-> 5 10:00:00:05:1e:82:5e:df 101 swsanrdmsm sp: 4.000G bw: 4.000G
2: 6-> 6 10:00:00:05:1e:82:5e:df 101 swsanrdmsm sp: 4.000G bw: 4.000G
swsanrdmst:admin> fabricshow
Switch ID Worldwide Name Enet IP Addr FC IP Addr Name
10: fffc0a 10:00:00:05:1e:7d:45:46 10.3.4.10 0.0.0.0 >"swsanrdmst"
101: fffc65 10:00:00:05:1e:82:5e:df 10.3.4.11 0.0.0.0 "swsanrdmsm"
I think all is correct
