Occasional Visitor
109772, [C2-5813], 1234509/0, CHASSIS, INFO, DS_5300B, S0,C0: Chip fault code=9 disables condor2 chip
I got an alert that we had lost half of our storage paths and saw the following errors.  The 24 ports in use went disabled.
Reboot the switch and see if it recurs? Running 7.4.1d.
Thanks!
2019/03/01-16:32:59:109749, [C2-5654], 1234508/0, CHASSIS, ERROR, DS_5300B, S0,C0: TXQ block 1st = 0x4, 2nd = 0x29500003, intr_cause = 0x3., OID:0x43010080, c2_intr.c, line: 4919, comp:insmod, ltime:2019/03/01-16:32:58:919590
2019/03/01-16:32:59:109772, [C2-5813], 1234509/0, CHASSIS, INFO, DS_5300B, S0,C0: Chip fault code = 9
disables condor2 chip, OID:0x43010080, c2_intr.c, line: 3262, comp:insmod, ltime:2019/03/01-16:32:58:919681
2019/03/01-16:32:59:109813, [BL-5215], 1234510/0, CHASSIS, WARNING, DS_5300B, ASIC error/fault message received for chip = 0 ,reason = 9, OID:0x43010080, pulsar_chip.c, line: 866, comp:emd0, ltime:2019/03/01-16:32:58:919768
2019/03/01-16:32:59:109834, [BL-5263], 1234511/0, CHASSIS, CRITICAL, DS_5300B, Faulting switch, OID:0x43000000, pulsar_blade.c, line: 1919, comp:emd0, ltime:2019/03/01-16:32:58:919858
2019/03/01-16:32:59:109855, [C2-5400], 1234512/0, CHASSIS, WARNING, DS_5300B, Trunk port[OID 0x43029838] goes OFFLINE in trunk group [2 7 ] , OID:0x43013880, c2_trksm.c, line: 3124, comp:emd0, ltime:2019/03/01-16:32:59:006040
2019/03/01-16:32:59:109876, [C2-5400], 1234513/0, CHASSIS, WARNING, DS_5300B, Trunk port[OID 0x43029839] goes OFFLINE in trunk group [3 6 ;] , OID:0x43013880, c2_trksm.c, line: 2845, comp:emd0, ltime:2019/03/01-16:32:59:006650
2019/03/01-16:32:59:109915, [C2-5400], 1234514/0, CHASSIS, WARNING, DS_5300B, Trunk port[OID 0x4302983a] goes OFFLINE in trunk group [6 ] , OID:0x43013880, c2_trksm.c, line: 2620, comp:emd0, ltime:2019/03/01-16:32:59:007465
2019/03/01-16:32:59:109936, [C2-5400], 1234515/0, CHASSIS, WARNING, DS_5300B, Trunk port[OID 0x4302983b] goes OFFLINE in trunk group [2 ] , OID:0x43013880, c2_trksm.c, line: 2620, comp:emd0, ltime:2019/03/01-16:32:59:008255
2019/03/01-16:32:59:109957, [C2-5400], 1234516/0, CHASSIS, WARNING, DS_5300B, Trunk port[OID 0x4302983c] goes OFFLINE in trunk group [5 4 ;] , OID:0x43013880, c2_trksm.c, line: 2845, comp:emd0, ltime:2019/03/01-16:32:59:008857
2019/03/01-16:32:59:109979, [C2-5400], 1234517/0, CHASSIS, WARNING, DS_5300B, Trunk port[OID 0x4302983e] goes OFFLINE in trunk group [4 ] , OID:0x43013880, c2_trksm.c, line: 2620, comp:emd0, ltime:2019/03/01-16:32:59:010391
2019/03/01-16:32:59:110001, [C2-5654], 1234518/0, CHASSIS, ERROR, DS_5300B, S0,C0: TXQ block 1st = 0x4, 2nd = 0x29500003, intr_cause = 0x3., OID:0x43010080, c2_intr.c, line: 4919, comp:insmod, ltime:2019/03/01-16:32:59:075644
2019/03/01-16:32:59:110021, [C2-5813], 1234519/0, CHASSIS, INFO, DS_5300B, S0,C0: Chip fault code = 9
disables condor2 chip, OID:0x43010080, c2_intr.c, line: 3262, comp:insmod, ltime:2019/03/01-16:32:59:075734
2019/03/01-16:32:59:110043, [BL-5215], 1234520/0, CHASSIS, WARNING, DS_5300B, ASIC error/fault message received for chip = 0 ,reason = 9, OID:0x43010080, pulsar_chip.c, line: 866, comp:emd0, ltime:2019/03/01-16:32:59:075815
2019/03/01-16:32:59:110064, [C2-5679], 1234521/0, CHASSIS, INFO, DS_5300B, S0,P-1(0): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x2 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028000, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:075920
2019/03/01-16:32:59:110085, [C2-5868], 1234522/0, CHASSIS, INFO, DS_5300B, S0,P-1(0): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028000, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:075999
2019/03/01-16:32:59:110106, [C2-5679], 1234523/0, CHASSIS, INFO, DS_5300B, S0,P-1(1): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028001, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:076328
2019/03/01-16:32:59:110128, [C2-5868], 1234524/0, CHASSIS, INFO, DS_5300B, S0,P-1(1): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028001, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:076407
2019/03/01-16:32:59:110149, [C2-5679], 1234525/0, CHASSIS, INFO, DS_5300B, S0,P-1(2): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x2 crc|G=0x0 2long=0x0 bados=0x2., OID:0x43028002, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:076704
2019/03/01-16:32:59:110169, [C2-5868], 1234526/0, CHASSIS, INFO, DS_5300B, S0,P-1(2): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028002, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:076782
2019/03/01-16:32:59:110190, [C2-5679], 1234527/0, CHASSIS, INFO, DS_5300B, S0,P-1(3): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x0 crc|G=0x0 2long=0x0 bados=0x2., OID:0x43028003, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:077076
2019/03/01-16:32:59:110227, [C2-5868], 1234528/0, CHASSIS, INFO, DS_5300B, S0,P-1(3): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028003, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:077154
2019/03/01-16:32:59:110247, [C2-5679], 1234529/0, CHASSIS, INFO, DS_5300B, S0,P-1(4): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028004, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:077605
2019/03/01-16:32:59:110268, [C2-5868], 1234530/0, CHASSIS, INFO, DS_5300B, S0,P-1(4): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028004, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:077683
2019/03/01-16:32:59:110303, [C2-5679], 1234531/0, CHASSIS, INFO, DS_5300B, S0,P-1(5): LOSYNC timeout detected; ns=0x50070003 enc_in|out=0x0 crc|G=0x0 2long=0x0 bados=0x2., OID:0x43028005, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:077985
2019/03/01-16:32:59:110324, [C2-5868], 1234532/0, CHASSIS, INFO, DS_5300B, S0,P-1(5): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028005, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:078063
2019/03/01-16:32:59:110344, [C2-5679], 1234533/0, CHASSIS, INFO, DS_5300B, S0,P-1(6): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028006, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:078363
2019/03/01-16:32:59:110363, [C2-5868], 1234534/0, CHASSIS, INFO, DS_5300B, S0,P-1(6): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028006, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:078441
2019/03/01-16:32:59:110384, [C2-5679], 1234535/0, CHASSIS, INFO, DS_5300B, S0,P-1(7): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028007, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:078739
2019/03/01-16:32:59:110404, [C2-5868], 1234536/0, CHASSIS, INFO, DS_5300B, S0,P-1(7): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028007, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:078817
2019/03/01-16:32:59:110424, [C2-5679], 1234537/0, CHASSIS, INFO, DS_5300B, S0,P-1(24): LOSYNC timeout detected; ns=0x50070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028018, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:079274
2019/03/01-16:32:59:110444, [C2-5868], 1234538/0, CHASSIS, INFO, DS_5300B, S0,P-1(24): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028018, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:079352
2019/03/01-16:32:59:110465, [C2-5679], 1234539/0, CHASSIS, INFO, DS_5300B, S0,P-1(25): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x2 crc|G=0x0 2long=0x0 bados=0x3., OID:0x43028019, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:079664
2019/03/01-16:32:59:110485, [C2-5868], 1234540/0, CHASSIS, INFO, DS_5300B, S0,P-1(25): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x43028019, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:079743
2019/03/01-16:32:59:110506, [C2-5679], 1234541/0, CHASSIS, INFO, DS_5300B, S0,P-1(26): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x1., OID:0x4302801a, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:080054
2019/03/01-16:32:59:110526, [C2-5868], 1234542/0, CHASSIS, INFO, DS_5300B, S0,P-1(26): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x4302801a, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:080132
2019/03/01-16:32:59:110548, [C2-5679], 1234543/0, CHASSIS, INFO, DS_5300B, S0,P-1(27): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x2., OID:0x4302801b, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:080440
2019/03/01-16:32:59:110570, [C2-5868], 1234544/0, CHASSIS, INFO, DS_5300B, S0,P-1(27): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x4302801b, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:080518
2019/03/01-16:32:59:110590, [C2-5679], 1234545/0, CHASSIS, INFO, DS_5300B, S0,P-1(28): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x4302801c, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:080984
2019/03/01-16:32:59:110611, [C2-5868], 1234546/0, CHASSIS, INFO, DS_5300B, S0,P-1(28): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x4302801c, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:081062
2019/03/01-16:32:59:110631, [C2-5679], 1234547/0, CHASSIS, INFO, DS_5300B, S0,P-1(29): LOSYNC timeout detected; ns=0x10070003 enc_in|out=0x2 crc|G=0x0 2long=0x0 bados=0x3., OID:0x4302801d, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:081378
2019/03/01-16:32:59:110652, [C2-5868], 1234548/0, CHASSIS, INFO, DS_5300B, S0,P-1(29): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x4302801d, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:081457
2019/03/01-16:32:59:110690, [C2-5679], 1234549/0, CHASSIS, INFO, DS_5300B, S0,P-1(30): LOSYNC timeout detected; ns=0x50070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x2., OID:0x4302801e, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:081771
2019/03/01-16:32:59:110718, [C2-5868], 1234550/0, CHASSIS, INFO, DS_5300B, S0,P-1(30): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x4302801e, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:081849
2019/03/01-16:32:59:110745, [C2-5679], 1234551/0, CHASSIS, INFO, DS_5300B, S0,P-1(31): LOSYNC timeout detected; ns=0x50070003 enc_in|out=0x1 crc|G=0x0 2long=0x0 bados=0x3., OID:0x4302801f, c2_intr.c, line: 1988, comp:insmod, ltime:2019/03/01-16:32:59:082161
2019/03/01-16:32:59:110773, [C2-5868], 1234552/0, CHASSIS, INFO, DS_5300B, S0,P-1(31): LOSYNC timeout detected; trunc=0x0 bad_eof=0x0 inv_arb=0x0 serdes_status=0x7d vcoctl=0x404., OID:0x4302801f, c2_intr.c, line: 1998, comp:insmod, ltime:2019/03/01-16:32:59:082238
2019/03/01-16:32:59:110800, [C2-5654], 1234553/0, CHASSIS, ERROR, DS_5300B, S0,C0: TXQ block 1st = 0x4, 2nd = 0x29500003, intr_cause = 0x3., OID:0x43010080, c2_intr.c, line: 4919, comp:insmod, ltime:2019/03/01-16:32:59:082700
2019/03/01-16:32:59:110829, [C2-5813], 1234554/0, CHASSIS, INFO, DS_5300B, S0,C0: Chip fault code = 9
disables condor2 chip, OID:0x43010080, c2_intr.c, line: 3262, comp:insmod, ltime:2019/03/01-16:32:59:082782
2019/03/01-16:32:59:110856, [BL-5215], 1234555/0, CHASSIS, WARNING, DS_5300B, ASIC error/fault message received for chip = 0 ,reason = 9, OID:0x43010080, pulsar_chip.c, line: 866, comp:emd0, ltime:2019/03/01-16:32:59:082862
2019/03/01-16:32:59:110885, [DGD-5006], 1234556/0, CHASSIS, INFO, DS_5300B, DIAGD: Unit Fault :type:0x8 subtype:0x40 object:0x1 unitnum:0x0 modid:0x5 reason:0x15., main.c, line: 1144, comp:dgd, ltime:2019/03/01-16:32:59:107636
2019/03/01-16:32:59:119529, [EM-5013], 1234557/0, CHASSIS, INFO, DS_5300B, Change in fltdisp status, now: 0x2, OID:0x43000000, em_board_lib.c, line: 1582, comp:emd, ltime:2019/03/01-16:32:59:116493
2019/03/01-16:32:59:119584, [DGD-5006], 1234558/0, CHASSIS, INFO, DS_5300B, DIAGD: Unit Fault :type:0x8 subtype:0x40 object:0x1 unitnum:0x0 modid:0x2 reason:0x15., main.c, line: 1144, comp:dgd, ltime:2019/03/01-16:32:59:118523
2019/03/01-16:32:59:119605, [EM-1134], 1234559/15109, FFDC | CHASSIS, ERROR, DS_5300B, Switch set to faulty, rc=20015., OID:0x43000000, em_board_lib.c, line: 1826, comp:emd, ltime:2019/03/01-16:32:59:119445
2019/03/01-16:32:59:124969, [RAS-5001], 1234560/0, CHASSIS, INFO, DS_5300B, Message EM-1134 caused FFDC event, ffdcd.c, line: 1054, comp:raslogd, ltime:2019/03/01-16:32:59:121216
2019/03/01-16:32:59:125142, [RAS-1001], 1234561/15110, CHASSIS, INFO, DS_5300B, First failure data capture (FFDC) event occurred., ffdcd.c, line: 1059, comp:raslogd, ltime:2019/03/01-16:32:59:121417
2019/03/01-16:32:59:477841, [TRCE-5001], 1234562/0, CHASSIS, INFO, DS_5300B, trace: 27739648, trace_device.c, line: 775, comp:Trace Process, ltime:2019/03/01-16:32:59:477714
2019/03/01-16:32:59:498714, [TRCE-1001], 1234563/15111, CHASSIS, WARNING, DS_5300B, Trace dump available ! (reason: FFDC)., trace_process_u, line: 142, comp:Trace Process, ltime:2019/03/01-16:32:59:498590
Frequent Contributor
Re: 109772, [C2-5813], 1234509/0, CHASSIS, INFO, DS_5300B, S0,C0: Chip fault code=9 disables condor2 chip
ASIC faulting and dropping 24 connections is obviously not a good sign.
Yes, reboot the switch to determine if the ASIC can recover.  However, you should really open a service request with your
SAN switch support for further investigation.    The FFDC trace should offer details from which an accurate action plan
can be given which mignt include replacing the 5300.
The "5000" series messages in the RASLog are Brocade proprietary and unpublished so it is unlikely you will find any details on
the definition of each message.
The comments and advise included are the author's and do not mirror the views and opinions of any company. Any comments, advise, statements or references are without warranty, liability or claims of expertise. You should seek the assistance of the professional entity for subject matter being pursued.
