Ethernet Switch
New Contributor
Accepted Solution
BCM53134O SGMII interface Reference Clock
We want to connect BCM53134O SGMII port with 2500base-X to Phy.
Do we need to supply an external reference clock to the SGMII_REFCLKN/SGMII_REFCLKP pin pair for normal operation?
If yes, which frequency and driving level is required?
Which register entry enables the external reference clock?
Broadcom
Re: BCM53134O SGMII interface Reference Clock
Hi,
Thanks the question.
It does not need external reference clock into SGMII_REFCLKN/SGMII_REFCLKP pins, just need the source 50MHz crystal clock.
Please leave the SGMII_REFCLKN/P pins as floating.
And please make sure to configure SGMII interface as 2500Base-X by following registers write sequence via SPI.
In addition, please be noted the BCM53134 does not support MDC/MDIO Clause45 for external 2.5G PHY registers access. Please use your external CPU to access external 2.5G PHY register if there is 2.5G PHY design on your platform.
Thanks,
Ryan
[Confiugre SGMII as 2500Base-X registers write]
SPI Access
MDC/MDIO Pseudo PHY Access
Length
Byte1
Byte0
Page(SPI)
Offset(SPI)
MDIO Address
Offset(MDIO)
0xe6
0x00
0xe6
0x00
0x1
0x01
0x14
0x3e
0x04
0x1f
0x2
0x80
0x00
0x14
0x20
0x04
0x10
0x2
0x0c
0x2f
0x14
0x3e
0x04
0x1f
0x2
0x83
0x00
0x14
0x20
0x04
0x10
0x2
0x01
0x0d
0x14
0x30
0x04
0x18
0x2
0xc0
0x10
0x14
0x3e
0x04
0x1f
0x2
0x83
0x40
0x14
0x34
0x04
0x1a
0x2
0x00
0x01
0x14
0x3e
0x04
0x1f
0x2
0x80
0x00
0x14
0x00
0x04
0x00
0x2
0x01
0x40
0x14
0x20
0x04
0x10
0x2
0x2c
0x2f
New Contributor
Thank you for the information.
We can continue our design and will try the register settings, as soon as the prototype boards are in.
