Application Delivery (ADX)
Anonymous
Problem with asymmetric traffic flow due to missing VIP failover
This is a follow-up to the Q I have posted a few second ago (). The setup is still looking like:
              UPSTREAM SUBNET
                   | A                 |B
           ServerIron 1 --- ServerIron 2
                   |C                  |D
          DOWNSTREAM SUBNET
ServerIron #1 is master by default and ServerIron #2 backup. There is a dedicated sync-link in between both SIs to synchronize the session table etc.
SECOND PROBLEM:
The problem is even worse in case remove link A. There is a failover from SI#1 to SI#2 in the UPSTREAM SUBNET talking about VRRP BUT SI#2 is not taking over the virtual servers. The virtual servers are still active (status: Owner) at SI#1 and NOTHING is working anymore. Is there any solution for this problem?
All I want is a failover from SI#1 to SI#2 - there should be a single SI being active at any time (no active-active or so).
Anonymous
Re: Problem with asymmetric traffic flow due to missing VIP failover
It is me again as in the other thread ;-). Let me try to add something to my example config from the other thread. You would like to ensure ALL VRRP instance and as well all virtual servers are doing a failover at the same time if I am not wrong.
Let me assume again you do have two VRRP instances only. Links A and B are port 1 of ServerIron 1 and ServerIron 2. Links C and D are port 4 of ServerIron 1 and ServerIron 2. There are two virtual server: 192.168.1.201 and 192.168.1.202.
Your config of the master switch should look like:
vlan 1
  router-interface ve 1
vlan 4
  untagged eth 4
  router-interface ve 4
router vrrp-extended
server vip-group 1
  vip 192.168.1.201
  vip 192.168.1.202
interface ve 1
  ip address 192.168.1.2 255.255.255.0
  ip vrrp-e vrid 1
    backup priority 109 track-priority 10
    ip-address 192.168.1.1
    vip-group 1
    track-port eth 1
    track-port eth 4
interface ve 4
  ip address 192.168.4.2 255.255.255.0
  ip vrrp-e vrid 4
    ip-address 192.168.4.1
    track-port eth 1
    track-port eth 4
The one of the backup switch:
vlan 1
vlan 4
  untagged eth 4
server vip-group 1
  vip 192.168.1.201
  vip 192.168.1.202
interface ve 1
  ip address 192.168.1.3 255.255.255.0
  ip vrrp-e vrid 1
    backup priority 100 track-priority 10
    vip-group 1
    track-port eth 1
    track-port eth 4
interface ve 4
  ip address 192.168.4.3 255.255.255.0
  ip vrrp-e vrid 4
    track-port eth 1
    track-port eth 4
The trick is again the following: the base priority of the master is 109 and the base priority of the backup is 100. There is a tracking priority (track-priority) of 10 configured. The based priority of a VRRP instance is getting decreased by the track-priority as soon as one of the ports which are getting tracked is going down. The example above is doing tracking for the ports 1 and 4. BOTH VRRP instances are configure to track the frontend and the backend port. Any link problem is going to result in a priority decreased for both VRRP instances and therefore in a failover of both of them. ALL virtual servers are part of the vip-group 1 and the vip-group failover is bound to the VRRP instance 1. You do have a failover of all VRRP IPs and ALL VIPs in the vip-group at the same time using this setup.
Is this what you would like to achieve?
