Hi. I have problem with BCM2835 processor on Raspberry Pi 2B single board computer. Namely which is PWM chan2.
I use PWM chan1 in serialise mode. Data is sent via PWM FIFO. While channel 1 works smoothly, channel 2 does not work. I need help. Short code for PWM channel1:
if(channel & PWM0)
for(pos = 0; pos <= (length) && BIT_IS_CLR(PWM_STA_FIFO_FULL, *pwm_statep); pos++) //fill empty FIFO till full
*pwm_fifop = data[pos];
*(pwm + PWM_CTL) |= PWM0_ENABLE ; //enable PWM0
for(; pos <= (length ); pos++) //move next data to FIFO
while(BIT_IS_SET(PWM_STA_FIFO_FULL, *pwm_statep)) //Wait for free place in FIFO
delayMicroseconds(20);
if BIT_IS_SET(PWM_STA_GAP0, *pwm_statep) //Check for GAP in STA
gapCounter++;
if BIT_IS_SET(PWM_STA_BERR, *pwm_statep)// Check for BUS Error in STA
berrCounter++;
while( BIT_IS_SET(PWM_STA_FIFO_EMPT, *pwm_statep)) // wait for channel works to the end
delayMicroseconds(380);
*(pwm + PWM_CTL) &= ~ PWM0_ENABLE; //desable PWM0
else if(channel & PWM1)
for(pos = 0; pos <= (length) && BIT_IS_CLR(PWM_STA_FIFO_FULL, *pwm_statep); pos++)//check if FIFO not full
*pwm_fifop = data[pos]; //fill FIFO with data
*(pwm + PWM_CTL) |= PWM1_MS_MODE|PWM1_USEFIFO | PWM1_SERIAL|PWM1_ENABLE ;
delayMicroseconds(20); //here endless loop waits for bit PWM_STA_FIFO_FULL go low
*pwm_fifop = data[pos]; //fill free place with next Data
if BIT_IS_SET(PWM_STA_GAP1, *pwm_statep)
gapCounter++;
berrCounter++;
while(BIT_IS_SET (PWM_STA_FIFO_EMPT, *pwm_statep)) // wait for fifo empty
*(pwm + PWM_CTL) &= ~ PWM1_ENABLE; //disable PWM chanel2
delayMicroseconds(10);
*pwm_statep = 0x1FFF;
return pos;
