DX Unified Infrastructure Management
 Problem with installing the robot on Red Hat Enterprise Linux 9.4
Solomon Melamed's profile image
Solomon Melamed posted Oct 16, 2025 02:23 PM
Hello everyone,
Maybe someone can help me, I installed robot (nimsoft-robot-9.40-1.x86_64) on Red Hat Enterprise Linux 9.4 server. Installation was successful but now controller is down with the message
Controller: robot_not_alive - not possible when robot is in passive mode
Controller: Down
Can someone help me, thanks.
Stephen Danseglio's profile image
Broadcom Employee Stephen Danseglio
Check the robot.cfg.
The robot should be set to normal mode.
robot_mode = normal
Steve
Solomon Melamed
But I want the robot to work in passive mode.
robot_mode = passive
All my robots work in passive mode.
By the way, even if I switch to normal mode, the controller doesn't come up either.
{Case#800400833}
Ok, Lol. Set the robot to loglevel 5, use a logsize of 50000.
Shutdown all robot processes using niminit stop or kill if niminit doesnt work.
Run niminit start and check the controller.log for more details.
Does the RHEL machine have anything blocking connections from the hub? firewalld/SELinux/Security software etc.
Steve
Did you follow the techdocs?
Manage Passive Robots
Did the robot install finish without errors?
Steve
Solomon Melamed
If I manually turn on the controller
export NIM_ROOT=/opt/nimsoft
export LD_LIBRARY_PATH=/opt/nimsoft/robot/lib:/opt/nimsoft/lib:/usr/lib64
sudo ./controller -d 5 &
, it starts.
ss -lntp | egrep '48000|48001' || true
LISTEN 0      128          0.0.0.0:48001      0.0.0.0:*    users:(("spooler",pid=30250,fd=6))
LISTEN 0      128          0.0.0.0:48000      0.0.0.0:*    users:(("controller",pid=30248,fd=4))
The Linux sys admin should be able to help you set this up.
To configure DX UIM to start automatically on Red Hat Enterprise Linux 9 (RHEL9), you need to create a systemd service file. The service runs the niminit script, which is the standard method for starting and stopping the UIM Nimsoft Robot Watcher service on Linux.
e.g., /usr/lib/systemd/system/nimbus.service
Steve
Solomon Melamed
The service starts, but the controller does not start.
started
Jason Allen's profile image
Broadcom Employee Jason Allen
I believe this robot (9.40) is too old for RHEL 9.4 - you should try installing robot 23.4.x and it should work better.  I would also suggest ensuring it can run correctly in normal mode first, then change to passive mode once you have it running successfully.
Solomon Melamed
Please send me the installation file for robot 23.4.x. on RHEL 9.4. I need manual installation (file .rpm)
Derek Child's profile image
Broadcom Employee Derek Child
Hi Solomon,
You can download the rpm files from support.nimsoft.com.
