DX Infrastructure Management
Tech Tip: UIM - data_engine database connections and thread_count_insert setting
Sep 07, 2016 05:35 PM
Document ID:  TEC1240487
Last Modified Date:  05/03/2016
Hide Technical Document Details
  • CA Unified Infrastructure Management
Releases
  • CA Unified Infrastructure Management:Release:8.4
  • CA Unified Infrastructure Management:Release:8.31
  • CA Unified Infrastructure Management:Release:8.2
  • CA Unified Infrastructure Management:Release:8.1
  • CA Unified Infrastructure Management:Release:8.0
Components
  • UIM - DATA_ENGINE:UIMDEG
Summary:
What is the best way to calculate or estimate the number of database connections I need to configure when I leverage the use of the data_engine's 'thread_count_insert' parameter?
The data_engine thread count relates to the threads for inserting high data rate RAW data. There are a number of other threads for other purposes and there is a thread pool.
Environment:
CA UIM 8.0 and higher
All supported databases
Instructions:
http://www.ca.com/us/support/ca-support-online/product-content/knowledgebase-articles/tec1240487.aspx
Statistics
0 Favorited
0 Files
0 Shares
0 Downloads
Tags and Keywords
Related Entries and Links
No Related Resource entered.
