Hi,
I'm working on TDm Portal version 4.10.29.
I'm trying to get a time without separator :.
The best way I found is to use the STRING function to convert the time value from HH:MM:SS to HHMMSS.
So, here's what I get:
~STIME~ -- @string(~STIME~,HH:MM:SS)@ -- @string(~STIME~,HHMMSS)@
gives
13:45:39 -- 13:45:39 -- 130100
Note that 13:45 is the right time. Each time I tried (within the data painter), the first two are changing accordingly with the real time by the third oen stays always the same.
I us the REPLACE function as a workaround to remove the separator.
But, I'm woundering why the STRING result does not give the same time, watever teh format is?
Any clue?
Thanks for time
jf
