Hi,
20.11 is really old. Since we have seen a similar problem with 20.41, it might already exist with 20.11.
As soon as you use Office Hours in the SLA, it happens that the calculation uses wrong time periods. If I remember correctly, the calculation periods are offset by one day. With a higher log level (I guess loglevel=4) you can see this nicely in the logfile (but unfortunately you have to convert EPOCH timestamps).
Original Message:
Sent: Mar 21, 2023 05:05 AM
Subject: Problem recalculating SLAs
Hello,
The SLA engine version is 20.11.
Thnaks.
Original Message:
Sent: Mar 20, 2023 09:07 AM
Hi,
which version of the sla_engine do you run?
Original Message:
Sent: Mar 17, 2023 01:16 PM
Hello,
We have a problem when we recalculate an SLA. When the period is all day, the recalculation is done well, but when we recalculate only a few hours of the day, the recalculation does not work.
For example:
This is the excluded period
and this is the recalculate
This example doesn´t work, but if the excluded period is the whole day, it does work.
Thanks for your help.
