HI Shalini
The log file has been reviewed. Please follow the procedure below
and let me know if it solves the reported issue:
1. On the Workstation Machine, open the file LISA_HOME/local.properties in
a text editor
2. Add the following property
lisa.server.https.cipher.suites=TLS_DHE_RSA_WITH_AES_128_CBC_SHA,TLS_DHE_RSA_WITH_AES_128_CBC_SHA256,TLS_DHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA,TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_RSA_WITH_AES_128_CBC_SHA,TLS_RSA_WITH_AES_128_CBC_SHA256,TLS_RSA_WITH_AES_128_GCM_SHA256
3. Save the file and restart workstation
4. Repeat the test and let me know the outcome
5. If the problem persists. then please share the workstation log file for
further analysis
regards
Sankar Natarajan
This electronic communication and the information and any files transmitted
with it, or attached to it, are confidential and are intended solely for
the use of the individual or entity to whom it is addressed and may contain
information that is confidential, legally privileged, protected by privacy
laws, or otherwise restricted from disclosure to anyone else. If you are
not the intended recipient or the person responsible for delivering the
e-mail to the intended recipient, you are hereby notified that any use,
copying, distributing, dissemination, forwarding, printing, or copying of
this e-mail is strictly prohibited. If you received this e-mail in error,
please return the e-mail to the sender, delete it from your computer, and
destroy any printed copy of it.
Original Message:
Sent: 11/16/2023 1:10:00 PM
Subject: RE: Mule Soft endpoint for REST API call with SSL certificate - java.net.SocketException: Connection reset by peer: socket write error
Hi Sankar,
I have followed the steps you mentioned and have posted the log file for your analysis as a private message to your inbox.
Original Message:
Sent: Nov 16, 2023 09:13 AM
Subject: Mule Soft endpoint for REST API call with SSL certificate - java.net.SocketException: Connection reset by peer: socket write error
Hi Shalini
Can you do the following to diagnose this further.
- Edit the file workstation.vmoptions in LISA_HOME/bin folder
- Add the following line and save the file
- -Djavax.net.debug=ssl
- Restart Workstation and repeat the test
- Share the workstation.log file from USER_HOME/lisatmp_x.x.x folder for
analysis
regards
Sankar Natarajan
Original Message:
Sent: 11/16/2023 8:44:00 AM
Hi Team ,
Our project is using Mulesoft Endpoint for the REST API calls. I am using SSL certificate, for which I have mentioned the details in the local.properties file in my workstation.
ssl.client.cert.path=C:\\Users\\12345\\DevTest\\Projects\\samplecert.com.pfx
ssl.client.cert.pass=password
https.protocols=TLSv1.2,TLSv1.1,TLSv1
lisa.net.trustStore=C:\\Users\\12345\\DevTest\\Projects\\samplecert.com.jks
lisa.net.trustStore.password=password
Note : Same password is used for the .pfx and .jks file.
When I try to run the sample test case in ITR mode, I get the below error . Please let me know what can be done to fix this.
| HTTP
| Step: AddCustomer
| Message: java.net.SocketException: Connection reset by peer: socket write error
| Trapped Exception: Connection reset by peer: socket write error
| Trapped Message: java.net.SocketException: Connection reset by peer: socket write error
STACK TRACE
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
at sun.security.ssl.OutputRecord.writeBuffer(OutputRecord.java:431)
at sun.security.ssl.OutputRecord.write(OutputRecord.java:417)
at sun.security.ssl.SSLSocketImpl.writeRecordInternal(SSLSocketImpl.java:879)
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:850)
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:720)
at sun.security.ssl.Handshaker.sendChangeCipherSpec(Handshaker.java:1144)
at sun.security.ssl.ClientHandshaker.sendChangeCipherAndFinish(ClientHandshaker.java:1333)
at sun.security.ssl.ClientHandshaker.serverHelloDone(ClientHandshaker.java:1243)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:373)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:535)
at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket(SSLSocketFactory.java:403)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:177)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:304)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:611)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:446)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
at com.itko.lisa.test.CommTrans.doSend(CommTrans.java:1082)
at com.itko.lisa.test.CommTrans.send(CommTrans.java:851)
at com.itko.lisa.test.CommTrans.sendPOST(CommTrans.java:811)
at com.itko.lisa.ws.rest.RESTNode.doSend(RESTNode.java:226)
at com.itko.lisa.ws.rest.RESTNode.doWebTrans(RESTNode.java:171)
at com.itko.lisa.ws.rest.RESTNodeBase.execute(RESTNodeBase.java:380)
at com.itko.lisa.test.TestNode.executeNode(TestNode.java:995)
at com.itko.lisa.test.TestCase.execute(TestCase.java:1297)
at com.itko.lisa.test.TestCase.execute(TestCase.java:1198)
at com.itko.lisa.test.TestCase.executeNextNode(TestCase.java:1183)
at com.itko.lisa.utils.ExecSubProcessNode.doFullExec(ExecSubProcessNode.java:354)
at com.itko.lisa.utils.ExecSubProcessNode.execute(ExecSubProcessNode.java:268)
at com.itko.lisa.editor.WalkThruPanel.prepAndExecNode(WalkThruPanel.java:1120)
at com.itko.lisa.editor.WalkThruPanel.access$900(WalkThruPanel.java:73)
at com.itko.lisa.editor.WalkThruPanel$10.doCallback(WalkThruPanel.java:1022)
at com.itko.util.swing.panels.ProcessingDialog$2.run(ProcessingDialog.java:195)
at java.lang.Thread.run(Thread.java:748)
Shalini Murukes
