Layer7 API Management
  • 1.  MTLS Problem
    Posted May 17, 2022 10:05 PM
    Hi,
    Im trying to use MTLS in the api management, i have follow the instructions from the link: Layer7 API Management
    This is my code:
    It works fine until the Authenticate against Internal Identity Provider.
    In the logs i see the message: "4201: No credentials found!" but it doesnt make sense for me.
    Can anyne help me?
  • 2.  RE: MTLS Problem
    Broadcom Employee
    Posted May 18, 2022 02:08 AM
    Your authentication assertion is targeting a response message that does not exist yet. I assume you want to authenticate the request message, so right mouse click the assertion, click Select Target Message and set it to Request.
    Note that when dragging in any targetable assertion into policy the Policy Manager is aware of the position relative to a routing assertion and automatically sets the target accordingly, so if it was dropped after the Return Template Response to Requestor then dragged up higher in the policy, then it would have been set to target the Response. This often catches people up.
    Jay MacDonald - Adoption Architect - Broadcom API Management (Layer 7)
  • 3.  RE: MTLS Problem
    Posted May 18, 2022 08:15 AM
    Hi.
    Thanks, I changed it to request and it worked!
  • 4.  RE: MTLS Problem
    Broadcom Employee
    Posted May 19, 2022 09:04 AM
      |   view attached
    Try this (see below screenshot) - this works for me.
    This electronic communication and the information and any files transmitted
    with it, or attached to it, are confidential and are intended solely for
    the use of the individual or entity to whom it is addressed and may contain
    information that is confidential, legally privileged, protected by privacy
    laws, or otherwise restricted from disclosure to anyone else. If you are
    not the intended recipient or the person responsible for delivering the
    e-mail to the intended recipient, you are hereby notified that any use,
    copying, distributing, dissemination, forwarding, printing, or copying of
    this e-mail is strictly prohibited. If you received this e-mail in error,
    please return the e-mail to the sender, delete it from your computer, and
    destroy any printed copy of it.
