VeloCloud
  • 1.  make DCI running through Velo SD-WAN overlay between Hubs
    Posted 20 days ago
    how to make 2 different DC VCE hubs using overlays over internet to establish DCI advertising routes to each other?
    In our current 2 DC/hubs scenario, we have to use separate underlay as DCI, Anyway we use Velo SD-WAN tunnel as DCI link?
  • 2.  RE: make DCI running through Velo SD-WAN overlay between Hubs
    Posted 19 days ago
    As the configuration of a hub is done at the client side (the client builds a permanent overlay tunnel to any site declared as) you simply have 3 different configurations to do.
    On client sides specify both DC-VCEs as hub
    On DC1- specify DC2-VCE as hub
    (on DC2- specify DC1-VCE as hub ) <-- this is not really needed but as you do not know which comes up first I tend to do this one as well
    But take care that if you have underlay DCI and overlay DCI the latter one will be preferred, and overlay tunnels need much more resources due to the CPU overhead for encryption and decryption and have a reduces MTU size as there are bigger tunnel headers
    KR alexander
