DX NetOps
  • 1.  Integration of Spectrum 24.3.13 with ServiceNow and Kafka for alarm forwarding
    Posted Sep 09, 2026 08:46 PM
    Good afternoon, Team,
    We have an urgent question. We are currently running Spectrum 24.3.13 with ServiceNow integration. Can we also integrate this same environment with Kafka for alarm forwarding?
    I look forward to your reply; your response is critical to addressing this requirement.
    Regards
  • 2.  RE: Integration of Spectrum 24.3.13 with ServiceNow and Kafka for alarm forwarding
    Broadcom Employee
    Posted Sep 10, 2026 02:04 AM
    Hi Eduardo,
    Spectrum's ability to publish to Kafka is described is a separate pathway for integration with "NetOps Portal, and third-party systems." The integration for sending alarms from DX NetOps Spectrum to ServiceNow is typically managed through the DX NetOps Portal (Performance Management) or via a direct ServiceNow Gateway (Service Desk Connector)
    This means you should be able to have alarms flowing to NetOps Portal for ServiceNow and simultaneously publishing to Kafka for other consumers without conflict as per:
    TechDocs : DX NetOps Spectrum 24.3 : Configure Spectrum to Publish the Alarms to Kafka
  • 3.  RE: Integration of Spectrum 24.3.13 with ServiceNow and Kafka for alarm forwarding
    Posted Sep 10, 2026 01:49 PM
    Hello, Mohammed
    Thank you very much for the reply. One more question: does sending alarms to independent systems affect the performance of the Spectrum OneClick web server? Regards,
  • 4.  RE: Integration of Spectrum 24.3.13 with ServiceNow and Kafka for alarm forwarding
    Posted 30 days ago
    You'd have to evaluate the size of the system, number of alarms and alarm occurrences to understand if existing OC server could handle the load.
    I would install a dedicated OC Server just for the purpose of the Kafka integration. The deployment actually supports 2 OC for HA for Kafka integration.
    Cătălin Fărcășanu
    Senior Consultant
    SolvIT Networks
