Hi Kris. I spent 2 hours with the technician and we couldn't reach an agreement.
I explained that error happens during the installation made by GPO or the dashboard, informed that it was to contact the IT team or Microsoft because the problem is with the proxy.
If anyone can give another view.
If I run the manual Symantec_Agent_install.exe installer on the computer, the proxy information appears in the log.
2021-06-14-15-31-42-038 : 0x1714 : Information : Proxy host or port or both are empty in manifest. Use browser settings.
2021-06-14-15-31-42-054 : 0x1714 : Information : Getting settings from IE
2021-06-14-15-31-42-054 : 0x1714 : Information : Proxy per Machine is not configured
2021-06-14-15-31-42-054 : 0x1714 : Information : AutoConfigURL
http://proxy.domain.com.br:9001/proxy.pac2021-06-14-15-31-42-054 : 0x1714 : Information : No manual proxy settings found
2021-06-14-15-31-42-054 : 0x1714 : Information : fsd::FSDProxySettings::determineBrowserProxySettings(118) : Using Proxy setting, autoconfig url -
http://proxy.domain.com.br:9001/proxy.pac2021-06-14-15-31-42-054 : 0x1714 : Information : Status reporting switched off. No Reporting URL specified in manifest
2021-06-14-15-31-42-054 : 0x1714 : Information : DING::CFilePackerEx::CArchiveInfo::Deserialize_legacy(631) : Segment header FSDManifest.js Deserialized
2021-06-14-15-31-42-054 : 0x1714 : Information : 64-bit package selected to install
2021-06-14-15-32-03-132 : 0x1714 : Error : fsd::FSDDataReporter::submitToServer(1696) : httpClient.GetRequest() failed, hr=0x80072EE2
If you send it via the dashboard or via GPO, you can't find it
2021-06-14-15-39-50-474 : 0x0F44 : Information : Proxy host or port or both are empty in manifest. Use browser settings.
2021-06-14-15-39-50-474 : 0x0F44 : Information : Getting settings from IE
2021-06-14-15-39-50-474 : 0x0F44 : Information : Proxy per Machine is not configured
2021-06-14-15-39-50-474 : 0x0F44 : Information : No manual proxy settings found
2021-06-14-15-39-50-474 : 0x0F44 : Information : fsd::FSDProxySettings::determineBrowserProxySettings(112) : Using Proxy setting, autodetect is set
2021-06-14-15-39-50-474 : 0x0F44 : Information : fsd::FSDEngineBase::Start(245) : Starting the job engine
2021-06-14-15-39-50-474 : 0x0F44 : Information : wWinMain(638) : spFSDEngine->Start() succeeded, starting message loop
2021-06-14-15-39-50-474 : 0x0F44 : Information : fsd::FSDBaseUI::OnUpdateJobInfo(783) : LPARAM - 9
2021-06-14-15-39-50-474 : 0x261C : Information : fsd::FSDJob::run(890) : jobState==ePreProcess
2021-06-14-15-39-50-474 : 0x261C : Information : fsd::FSDJobEngine::GetPreviousDownloadDuration(3441) : Failed to read download duration registry key
2021-06-14-15-39-50-474 : 0x261C : Information : fsd::FSDJobEngine::OnJobEvent(1106) : Sending jobEvent 0
2021-06-14-15-39-50-474 : 0x0F44 : Information : fsd::FSDBaseUI::OnUpdateJobInfo(783) : LPARAM - 0
2021-06-14-15-40-11-598 : 0x261C : Error : Unable to connect
https://us.spoc.securitycloud.symantec.com/status, hr 0x80072EE2
2021-06-14-15-40-32-660 : 0x261C : Error : Unable to connect
2021-06-14-15-40-53-706 : 0x261C : Error : Unable to connect
2021-06-14-15-40-53-706 : 0x261C : Information : fsd::FSDJobEngine::OnJobEvent(1106) : Sending jobEvent 12
2021-06-14-15-40-53-706 : 0x261C : Information : fsd::FSDJob::run(1017) : jobState==eFinished
2021-06-14-15-40-53-706 : 0x0F44 : Information : request to show/hide main window
2021-06-14-15-40-53-706 : 0x261C : Error : fsd::FSDJobEngine::OnJobEvent(748) : Handling eJobFinish failure, engine state=2 job failed with hrJob=0x80047ECD
2021-06-14-15-40-53-706 : 0x0F44 : Information : send message to display window
2021-06-14-15-40-53-706 : 0x0F44 : Information : fsd::FSDBaseUI::OnUpdateJobInfo(783) : LPARAM - 12
2021-06-14-15-40-53-706 : 0x0F44 : Information : DING::CFilePackerEx::CArchiveInfo::Deserialize_legacy(631) : Segment header FSDManifest.js Deserialized
2021-06-14-15-40-53-706 : 0x0F44 : Information : 64-bit package selected to install
2021-06-14-15-40-53-706 : 0x0F44 : Information : Proxy host or port or both are empty in manifest. Use browser settings.
2021-06-14-15-40-53-706 : 0x0F44 : Information : Getting settings from IE
2021-06-14-15-40-53-706 : 0x0F44 : Information : Proxy per Machine is not configured
2021-06-14-15-40-53-706 : 0x0F44 : Information : No manual proxy settings found
2021-06-14-15-40-53-706 : 0x0F44 : Information : fsd::FSDProxySettings::determineBrowserProxySettings(112) : Using Proxy setting, autodetect is set
2021-06-14-15-40-53-706 : 0x0F44 : Information : Status reporting switched off. No Reporting URL specified in manifest
2021-06-14-15-40-53-706 : 0x0F44 : Information : fsd::FSDBaseUI::showFsdDialog(1210) : Display FSD dialog with id 18
2021-06-14-15-40-53-706 : 0x0F44 : Information : fsd::FSDBaseUI::showFsdDialog(1224) : FSD executed in silent mode or do not have access to desktop, suppress any dialogs
2021-06-14-15-40-53-706 : 0x0F44 : Information : fsd::FSDBaseUI::stopJobAndDisableStartAfterReboot(661) : Force job to exit with 500ms timeout
Original Message:
Sent: 06-08-2021 04:32 PM
Subject: Installation problem by GPO and dashboard
I understand that this is frustrating. At this point, we have to follow the process for support. I do appreciate you confirming that you have followed the documentation, that's a big help. I'll see if there's any other info I can find out, but this is something that I have not personally seen before.
Kris Gainsforth
Solutions Engineer
Broadcom
Original Message:
Sent: 06-08-2021 04:13 PM
Thanks for the answer.
I've already checked these two documentations.
The problem that happens is that it starts installation using the proxy, but after it downloads the .dat file it ignores the system's proxy and ends up being blocked in the firewall.
In the .mst file I configured some proxy entries, but they gave an error at the beginning of the process.
Either the parameter I put is wrong or it doesn't allow changing the file.
This behavior occurs in both cases, installation via GPO or via the console.
On a machine I installed it manually without problems. This way I was able to do the discovery and send the package.
I've already questioned support for entries that could be placed in the proxy .mst file, but it doesn't answer that. Just say you'll check with the senior team.
Original Message:
Sent: 06-08-2021 01:43 PM
As far as installing by GPO, that shouldn't make a difference. The endpoint just needs to have a clear path to the URLs listed in my other post.
Kris Gainsforth
Solutions Engineer
Broadcom
