Hi Rasika,
Im not sure but you can check out pagerdutygtw which works on 32 and 64-bit systems.
https://www.pagerduty.com/wp-content/uploads/integration-guide-assets/CA-UIM-PagerDuty-Gateway-Probe-Guide-.pdf
Steve
Steve Danseglio
Senior Principal Support Engineer (Technical Support Engineer 5)
Broadcom Software-IMS Division
UIM Certified Expert
KCSv6 Practices Certified
Certified Customer Success Manager (CCSM) Level 1
Original Message:
Sent: Feb 26, 2025 09:39 AM
Subject: Has anyone implemented solution for converting emails from 3rd party tools to alerts in UIM
Has anyone implemented solution for converting emails from 3rd party tools to alerts in UIM?
I have one through below link but the probe is for 32.bit OS not 64.bit.
https://community.broadcom.com/enterprisesoftware/communities/community-home/librarydocuments/viewdocument?DocumentKey=e9ea52e4-528c-4d88-9cf4-ebf763833236
Does anyone has 64bit version for same or any other way to achieve same?
