AppWorx, Dollar Universe and Sysload Community
  • 1.  Guide for SAAS for DUAS (or similar)
    Posted Jan 28, 2026 11:04 AM
    Looking to expand automation into the cloud and see there is a SAAS for DUAS (well it sounds like that).
    Is there a basic guide of what this is and how to set up?  Its about automating things in the cloud and control.
  • 2.  RE: Guide for SAAS for DUAS (or similar)
    Broadcom Employee
    Posted Feb 26, 2026 02:03 AM
    Hi Angus,
    I think there is no SAAS for DUAS at the moment. I can get more information later though if any.
    Ensure your Dollar Universe environment has the Web Services Manager installed. This allows DUAS to trigger and control cloud-native tasks (like Lambda functions or Azure logic apps).
    https://knowledge.broadcom.com/external/article/224776
    If your goal is "control and visibility" across the cloud, you connect your UVMS (Univiewer Management Server) to AAI. AAI acts as the SaaS layer that "reads" your Dollar Universe data to provide advanced automation insights.
    You can install Dollar Universe Application Servers (DUAS) directly on cloud VMs (EC2, Azure VM).
    • Note: If installing in a cloud cluster (like a Linux Azure Cluster), be aware of specific networking configurations.
    https://knowledge.broadcom.com/external/article/253435
    Hope this helps
  • 3.  RE: Guide for SAAS for DUAS (or similar)
    Posted Feb 27, 2026 05:19 AM
    Hello @Saicharan Palagiri @Angus Reid,
    Sai is correct in saying that Dollar Universe does not currently propose a SaaS option.
    The Manager for Web Services, Triggers, Dollar Universe Web Services Enablement (DUWS), as well as the DevOps toolkit can allow for integration of Dollar Universe in a cloud environment. As Sai mentioned, Dollar Universe can be installed on cloud VMs. It can also be installed as Docker containers:
    https://techdocs.broadcom.com/us/en/ca-enterprise-software/intelligent-automation/dollar-universe/7-01-11/Installing/Install_on_UNIX_LINUX/docker.html
    However, Dollar Universe does NOT integrate with AAI (Automation Analytics and Intelligence), though other Broadcom (and even non-Broadcom) schedulers do. This might be something that is added in the future, but it is not in the current public roadmap.
    I hope this helps!
    Regards,
    Domenico Cotugno
    Tricise Automation
