VMware NSX
  • 1.  About restoration of NSX Edge
    Posted Jun 29, 2017 01:04 AM
    Hello.
    To restore the NSX Edge after restoring the settings to the new NSX Manager r Can you deploy by displaying the displayed NSX Edge?
    Just by restoring the settings to the new NSX Manager, NSX Edge recognizes that the virtual appliance will not be deployed simply by being displayed in "Web and Sphere Client" Netwoking and Security "NSX Edge".
  • 2.  RE: About restoration of NSX Edge
    Best Answer
    Posted Jun 29, 2017 08:24 AM
    Hi,
    If I'm understanding your question correct; you've restored a NSX Manager backup on a new NSX Manager appliance deployment and want to redeploy the NSX Edges from the backup configuration - because they are not deployed automatically when restoring a NSX Manager backup.
    To redeploy the NSX Edges that you had in your previous environment, simply right click an Edge in the "NSX Edges" overview and choose either "Deploy" or "Redeploy" and the Edge will be deployed. Make sure you have the same computer/storage resources available though (same names), or update the Edge placement options in its settings first.
    Hope that helps,
  • 3.  RE: About restoration of NSX Edge
    Posted Jun 29, 2017 11:42 PM
    Thank you.
    I understand that NSX Edge will not be deployed simply by restoring the configuration to NSX Manager.
    There is one doubt.
    Does "Redeploy" automatically deploy NSX Edge to its original location?
    Or do you need to select host and storage manually?
  • 4.  RE: About restoration of NSX Edge
    Posted Jun 30, 2017 01:02 PM
    It will deploy it in the same location as it previously was deployed. So if that datastore, cluster, portgroup no longer exists; make sure you update it in the configuration of the Edge before you redeploy.
  • 5.  RE: About restoration of NSX Edge
    Posted Jul 04, 2017 11:48 PM
    Thank you
    It is a good answer.
